Wanted: Gen 1 OEM Chrysler Radio
TrevShand
Charlottesville, VA
Just trying to see if anyone might know where I can source a new Gen 1 head unit. I've looked around and haven't seen anything but thought I'd try.
Also, willing to buy a non-working unit for the right price.
Thank you.
Trevor
RCR88
CARROLL IA
Same here but I guess they were made with different connectors from 92-95 so you have to be careful what you buy? Read that in a few places, unsure if it's accurate or not.
v3ry5ubt13
IL
I’ve got one out of a 95’. I pulled it last summer to upgrade to Apple CarPlay. It’s working.
RCR88
CARROLL IA
v3ry5ubt13-What does your Car Play set up look like? Was looking at a few options.
phipplet
Friendswood, TX
If you need numbers or anything, I have mine completely out, including the CD changer. It took me several years to piece together an original stereo system for my 94. I have an extra CD changer in the box if interested.
I had to replace the entire wiring system because the PO cut all the amplifier connections. don scharf automotive Helped with the wiring. Last I checked they didn’t have any Gen1 Alpine cassette decks.
Good luck!
v3ry5ubt13
IL
Here's what I went with. It wasn't an arm and a leg and it works beautifully. It tilts four directions and slides up and down and is easily removed. I also swapped out the outlet for two usb charging ports. One is connected to only power and one is connected to the apple/android auto usb port on the radio.
phipplet
Friendswood, TX
This is the extra CD Changer I have;
Now that I think about it, this was the extra for my 99 Prowler. Here’s one like mine in the Viper;
