Can someone measure the stock SRT ride heights for me?
Sean Roe
Jacksonville, FL
I need the height, from the ground to the frame, just behind the front wheels and just forward of the rear wheels on a stock SRT if someone can help me out with that.
We're working on an interesting little project and need to get the chassis height set correctly.
Marrying 1958 Chrysler styling with 2005 technology....
Thanks in advance.
Regards,
Sean
steve911
Cottage Grove, Wi.
On my '04 the rear measurement is 5 1/2 inches. The front is 4 3/4 inches.
It should be noted that the jacking points ( the "V" shaped metal pieces) stick down approx 1/2 inch further than the bottom of the chassis itseld.
Hope this helps.
Sean Roe
Jacksonville, FL
Thank you very much. That's exactly what I needed. The factory book referenced the heights off a gauge, not the ground.
Eagle
Mine is 5 1/8 front and 5 1/2 rear to the frame with 1/2 less to jacking point. 1100 mile 04 SRT-10.
EmmmaHot
