Can't find Methanol (winter formula)
FLX109
Massachusetts
Can\'t find Methanol (winter formula)
I went to walmart looking to buy about 4 or five cases of the winter formula, the 20 below zero stuff for my methanol/water injection, Its all gone all they have is the summer for almost $3.00 a gallon, I have to start looking on Ebay I guess.
FLX109
ViperBing
Eastern Shore of Maryland
Re: Can\'t find Methanol (winter formula)
Is the -30 stuff ok to use? I found some in K-Mart and it is pink in color. I think it was called Winter Warrior Power Deicer.
Schulmann
Canada
You will have to wait until november ...
Qualitywires.com
Louisville, KY
Look up in the phone book for those little go karts that run on alcohol. You can buy straight **** from them for about $5 per gallon and make your own mix. I personally think's its better than windshield washer fluid...and cleaner.
Qualitywires.com
Louisville, KY
also you can use the stuff call "heet" with is **** and make your own mix.
Simms
Pittsburgh, PA
I was told at Advance Auto that they stock carrying the winter stuff in the summer but if you really need it they can order you a crate of it.
You may want to check it out.
Mando9595
