CD changer (what model is stock)
SNAKE BITE
Belvidere, Illinois
I ran a cd changer cable for my stock alpine (94 rt/10) and remember reading there is a certain alpine changer which will work with this. Does anyone know the model #? Thanks, Andy
SNAKE BITE
Belvidere, Illinois
Thanks, Is this one fine?
YOU ARE BIDDING ON 1set OF ALPINE CHM-S655RF 6 DISC CD CHANGER WITH FM MODULATOR. FM MODULE CAN BE HOOKED UP WITH YOUR ANY KIND OF HEAD UNIT. THE 6 DISC CHANGER IS CHM-S630
*FEATURES*
CHM-S630 M-BUS CD CHANGER WITH FM MODULATOR
EASY ADD ON TO ANY HEAD UNIT THRU FM FREQUENCY
PLL SYNTHESIZER FM MODULATOR
OUTPUT LEVEL ADJUSTMENT
REPEAT
MUSIC SENSOR AND SCAN
ELAPSED TIME DISPLAY
HIGH SPEED ANTI-VIBRATION MECHANISM WITH SILICON OIL DAMPERS
5 POSITION MOUNTING (0 ~ 90 DEGREE)
REMOTE CONTROL INCLUDED
carguy07
Cuyahoga Falls, OH, USA
I bought mine on ebay. They pop up from time to time. You really want to get the adapter. It allows you to use the stock head unit controls and does not screw around with an FM Modulator
Cal Cobra
Brentwood, CA
Andy if you get the CHA-S634 along with the M-bus to Ai-NET cable and the Alpine adapter part # 4913, you can play MP3s on your factory deck.
Cal
Randy
Earth?
Just to further confuse the issue: the CD changer I put on my '95 RT/10 was an Alpine "CHM-S601" (which I bought and installed in November of 1997). However, the factory head unit has the sound input as RCA jacks, while all of the Alpine changers have the sound input in the DIN cable. So, I had to cut the cable going to the changer and put a couple of RCA plugs on it.
For what its worth....
A couple years later, I got rid of the changer (and recovered precious trunk space), and replaced the head unit with an Alpine CDA7897 CD/MP3 (and AM/FM/etc) head unit, which also automatically hides the faceplate when the unit is off - looks like a removable faceplate unit with the faceplate removed; ideal for an RT that I would park many places unattended. And, you can burn a CD with around 170 MP3s on it, thus getting rid of the need for a CD changer.
