BOTTLEFED
I did a quick search on this and didn't find a definitive answer to my question.
So what I would like to discuss is:
What is needed to swap the pistons from cast to forged? - parts, machine work, etc.
I'll be doing all the tear down and reassembly myself so the labor cost will only include the machine work.
The problem I found in previous threads about this is everyone giving advice on what to do while you are in the motor.
I DO NOT need to know what I can or should do while the motor it apart. I have inspected the main and rod bearings and they look great. In fact this motor was out of a '98 and originally should have had forged pistons but looks like it was rebuilt and cast pistons were installed ( I seem to be running into this a lot
), thus it should be in pretty good shape since there were not many miles on the car (28k). The heads are from another motor.
I guess my main question is, Do I need to rebalance the assembly when changing the pistons?
It seems like when Arrow rebuilds these motors they like to replace the forged pistons with cast. So do they rebalance the crank when they do this or do they just swap them out?
Is there a large enough difference to throw off the crank?
My other dilemma is going with new rings or just using the old ones. Are the rings on the cast pistons the same as the ones for the forged pistons? I'm guessing a good hone on the cylinders will in order, but will rings be necessary?
I would like experienced answers, not "well I heard..." answers. I also DO NOT need to know about cast pistons and their advantages, or any questions why I want to change the pistons. I have a Roe S/C and I plan to run N2O. I'm tired of going through motors and I need to get this car on the road before winter comes. I'm not looking to send this motor out to get rebuilt; it doesn't need that. I just want to change the pistons.
Thanks you in advance for your knowledgeable help. I know I can count on you guys for advice
-Tim
-Tim
