Chrome Halatron Extinguishers with mounts...
Sean Roe
Jacksonville, FL
All our supplier issues have been taken care of and we now have about 20 Chrome 2.5 Lb extinguishers on the shelf. We offer these with our passenger seat mounting bracket (longer than before to accomodate the anti-sub belts) for $139.95 total.
Thanks for your patience,
Agree this a GREAT product...EASY to install in a secure place...and they look FINE...more importantly, in the event you ever need this device, it is VERY easily reached, and MUCH easier to clean up Viper after using it...the compound type devices are pure HELL to remove residue!!
Sean Roe
Jacksonville, FL
The ones we've been building up the last few weeks have 1" longer legs than before. If you have any interference problems, we'll gladly exchange it for a longer one.
This applies to everyone.
Hi, Mark. If you are worried about antisubmarine belt, and are using Sean's original brackets...install bracket as shown in instructions, WITH antisub. belt and anchor pulled toward rear, then check for clearance. I was worried about this on our 99 ACR and 01 GTS ( the latter with dealer installed 5 point harness)...removed bracks in both cars, straightened the angle (bend)in the bracket somewhat, reinstalled brackets in both cars and all fit perfectly. If by some chance your car's antisub. anchor slightly more forward in location, Sean's longer bracket will work well.
