Clearing 2002 RT10 ABS Light
hemihead
Commerce Township, MI
On my last pass at Autocross yesterday I noticed my ABS light was on. It was a very hot day plus we were on asphalt all day so I was thinking I toasted a wheel speed sensor. Tonight I was looking at them and found the right front sensor to be very loose, I'm lucky it didn't fall out. I tightened it up and pulled the positive cable for about ten minutes to clear the codes. I put the cable back on, started the car and the ABS light is still on. Can this code be cleared by pulling the cable or do I need to take it to the dealer and pay those clowns $75 to clear it with the DRB tool?
01-02 RT10 ? My 01 ACR would do that when the pressures got higher on one side after tracking.
I think if you drive it 3-4 times with no fault sensed it will go out.
IMPORTANT Be sure your tire pressures are correct at all 4 , and no funky tire sizes involved?
H
hemihead
All stock wheel sizes and the PS 2's I bought from you are great. I'll double check the tire pressures.
As always, thanks for the help.
Jerry
countourcafe
