Clutch Pedal and Clutch Master Rod
chnco
So I was driving along the other day and my clutch pedal just went dead and after a short heart attack, I costed to a stop safely.
I troubleshooted the problem in the parking lot and the clutch master cylinder rod simply just came disconnected from the clutch pedal itself. I simply put the rod back into the pedal and was good to go. When I jump back in the car, the same thing happens 5 minutes later!
It seems that the pedal/rod is simply a hole with a rod that goes thru and no type of cotter pin to save it from sliding out? Am I missing something here?? It seems it would be easy for it to slide out anytime!
C
chnco
Upon further research, I've found that the "birdcage" is a common problem?
I really want to drive the car this weekend, and I'll order the part tomorrow. Anyone just put a zip tie in place of the cage for a couple of days?
hou99gts
Rosharon, TX
Yes, the birdcage is a common problem.
Yes, I tried the zip tie, and broke it also. Then got bailing wire and that held for a few days until my birdcage showed up. The more bailing wire the better.... :)
C
chnco
Well I got bored today and really didn't trust the "birdcage" (although I ordered one anyway).
So I went to my local Home Depot and went to work. I ended up with a 5/16th hitch pin that fits nice and snug and is METAL. I also tested with a 5/16th ring cotter pin, but was insanely difficult to put on.
I think I'll keep this setup on and see if it breaks, it looks MUCH sturdier than the plastic birdcage.
C
chnco
And for those who wanted to bypass the stock clutch switch, you simply have to bridge the male connectors, takes all of 5 minutes.
Qdog
