cover on fog lights
prowl
Gautier,MS,Jackson
Can someone tell me how to take the clear cover off on a 97 viper I need to clean inside it. look like you can turn it and it will come off but I do not want to try it because I have a fear of breaking it.
red98GTS
Arizona, USA
Yes, Steven.....look closely and you will see three little "tabs" holding the lens into the fascia. Take a plastic trim stick or if you are careful, you can use a tiny screwdriver, and disengage these retainer tabs and the lens will come out. To install it back, insert the lower tab into the hole in the fascia, then flex the cover and insert the others. Easy. I'm assuming your 97 is like my 98. I think it is.
Pete the ex glass guy
Shelby3
liu;g
I wouldn't use any kind of tool. Mine always have come out by hand focusing on one tab at a time, starting on one of the upper tabs. 97 GTS
Mando9595
