Fog light replacement Gen IV
ClovisViper08
California
If you are wanting to go aftermarket Miramoto’s look really good on the G3/4.
XXXX
RockHill, SC
If you're not trying to stay Stock, you will almost certainly like the Morimoto replacement better. I did.
ClovisViper08
California
is the install easy?
Very simple, I took off my front wheels to access the fog light cover. Once off, the bolts holding the fog light bracket were a bit tight as a have bigger hands. Everything is basically plug and play from there.
My old ones were pretty bad
