Diagnosis Help Needed: Battery or Alternator?
Earl_H
MI
Had the Viper out yesterday after about 2 weeks of inacticity. Drove it to the gym (~ 20 miles) no problem. On the way home the battery voltmeter went to 0, the rpm guage went dead, the radar detector started to pulse off/on, radio eventually went out. Then the battery light came on. Got the car home, turned off the ignition. Tried to restart but the battery went dead. Put a recharger on the battery for about 3 hours and then sucessfully restarted the car. Does this sound like an alternator problem or a battery problem?
E
Earl_H
MI
Let the engine idle for about 15 mins. and the volt meter went to 0, car still ran.
luc
Paso Robles CA
make sure that your battery connections are tight and connect a voltmeter whith the engine idling.
Volts shoud be above 13.5/14.
If not, problem is with your charging system.
Luc.00GTS
E
Earl_H
MI
Strange thing...AEM reads about 9.5-10volts. When I use a voltometer it pegs at 15v.
Randy
Earth?
One way to test - disconnect the battery at the engine compartment battery connection and put a charger on it (the battery cable, not on the connection to the car :cool: ). Let it sit on the charger for a while (a number of hours at least), then disconnect the charger (leaving it disconnected from the car), and let it sit some more - overnight perhaps. Then re-attach it to the car and see if it will start the car. If it starts the car, meaning the battery is accepting *and* holding the charge, it would seem to be the charging system. If it won't start the car, its likely the battery. Or, you can take it to a place that has a battery load tester and save a bit of waiting time.
E
Earl_H
MI
Turns out it was the AEM, replaced Alt. and Speedo for nothing...well it was a good exercise in learning more about the Viper electrical system. Live and learn. :)
Thanks to all that offerred help on this (especially JD).
