Would there be interest in a set of four two piece brake rotors that are cross drilled, slotted and heat treated. The center hats are machined from 6061-T6 bar stock and the rotors are cast iron with directional vanes and coated. These are suitable for heavy track use.
I am thinking about making a batch of these if there is interest. The cost would be around $1150 per set of four with plain aluminum hats or $1200 for hard coated hats. The main benifit of these rotors will be a 35lbs weight savings over stock.
These will be bolt-on for GEN 3 cars.
