Discussion on Cams lately
Martin D
Dunwoody, GA USA
Seems like there has been quite a bit of talk about cam specs....
If anyone is interested, I still have the stock Cam from my 98. I am willing to part with it.
Regards,
HouseofSpeed
Houston, TX
The Gen 2 will fit the Gen 1, but why?
If one were going to make the effort to install a "new" cam...why use a stocker of any vintage? Too much overlap and marginal lobes...seems like a waste of cash and energy.
Chuck 98 RT/10
tampa, fl USA
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by HouseofSpeed:
<HR></BLOCKQUOTE>
"Too much overlap?" That's what gives it the rough ride, which we like!!!
How much does a new aftermarket cam for a Viper cost? If you could get a barely used stock one for free then that's not a bad idea.
My question is why is the cam swap being done? Maybe you have a newer Viper and want the rough idle of the earlier Viper? Or you're doing a complete engine rebuild.
M
Martin D
Dunwoody, GA USA
Good Morning!
I got to the office this AM and had several emails about the Cam.
BLS actually responded first. I had no idea this would generate so much interest.
So BLS, the cam will be on it's way by Monday. I will call you today.
Also, I think Kyle makes a pretty good point, that it is quite a bit of work to install a Stock Cam. I would take Treynor's direction and also get some headwork while you are in there. Also - extrude hone that intake!
Regards,
HouseofSpeed
Houston, TX
Chuck...its not the overlap that gives the idle quality....I can change the LSA and make a cam with neg overlap lope. 60+ degrees of overlap over-scavenges the cylinder and contaminates the incoming intake charge....which all equal lost power.
Overlap and LSA are not the same.
treynor
Redwood City, CA
Yah, as long as you're giving away stock parts, do you still have your stock forged pistons? Those could come in handy if I have *ahem* an overzealous NOS night...
Chuck 98 RT/10
tampa, fl USA
<HR></BLOCKQUOTE>
Not disagreeing with you Kyle, but what DOES give it the rough idle and what is LSA?
