does anyone have the pirelli rosso 345/25/20?
ulllose
Brunswick, Ohio
I want to order these forgeline wheels in a 20" rear but can't seem to find tires to fit them.
I'm sure i'm not the only one running 20's on the rear, (or atleast want to).
Thanks to anyone with input.
MikeR
The Pirelli's were back ordered , then I heard possibly discontinued. Most guys are starting to order the new Nitto pictured above. Otherwise the Michelin PS2 335 is actually wider then the Pirelli 345, but the michelin is I think a half inch taller then stock, while the Pirelli is almost a half inch shorter then stock.
U
ulllose
Brunswick, Ohio
I also heard that the tire has been discontinued (per Tirerack) but then they said it was backordered...??
The ps2 tire in a 20" application says it will fit rims from 11"-12.5" in width, so, i was assuming that would not work.
Cape Coral, FL
I have been hearing "Discontinued" over and over again.
Michelin PS2's all around seem to be the way to go...
Cape Coral, FL
the new PS2's look GREAT, just mounted up a set of them yesterday.
335/30/20, and 295/30/19
The 335' are actually 345's, just .1" under. they look great all around.
GTSNRT10
Tennessee
I have a couple, but I don't want to have to part with them.......unless you want them worse than I do :omg: :D
U
ulllose
Brunswick, Ohio
Well that must be "if the price is right" lol
I'm on hold as of right now. I have a set of factory 5 stars sitting here and i can't decided to put these on or order the rims i really want.:dunno:
GreatWhiteKAC
