Door glass fit 08 Coupe
racer22
Fresno
The top of the passenger and driver door glass are starting to hit the roof when closing the door. I'm a little reluctant to let someone get in and adjust them. Anyone else have this issue.
hyph
You need a new window regulator most likely.
Brian E
Granger, Indiana, USA
Try this:
Index Viper Windows
1) Get in car and close the door.
2) Turn the key on to the second position. Don't start.
3) Cycle window down and hold switch for 5 seconds and release.
4) Cycle window up and hold switch for 5 seconds and release.
5) Repeat 2 more times.
R
racer22
Fresno
Brian: does this reset/adjust the mechanism for proper calibration and fit? Thanks, Jeff
Brian E
It sets the proper height for the up and down position of the window. (assuming your window regulator is working properly)
If you have had a dead battery/battery replacement, its very common to have to index your windows. Once set, your window glass should drop about 1/4 inch when opening the door. It will automatically go up to the full closed postion once the door is fully closed.
johniew398
Bentonville, Arkansas
I had the same problem with my 08. I tried the adjustment procedure several times and that didn't work. I finally had the dealer replace the window regulator and it fixed the problem.
R
racer22
Fresno
Brian: It took about 5 cycles but it appears to finally be there. Very close tolerance; glass to roof lip. My tech just installed a battery tender; maybe that's what happened? Thanks for your help.
