EBC GREEN
GTSPOWERED
Ohio
I just installed EBC Greens last week and weather permitting this weekend I got the chance to try them out. All I can say is great. No noise no mess and great stopping power. The only thing that I disliked is the turning process of the rear piston while retracting it. All I have left to do for maintenance this year is to change the rear end lube and the antifreeze both do not look like fun. But you have to pay to play.
95Viper
Phoenix
The rear lube is easy...as long as you have two people and a $10 suction pump from Autozone. It looks like a bike pump but has hoses on each end. You get someone to feed one end of the hose all around the inside of the rear while you pump about a billion times until all is out.
Then, add the 4 oz. additive and then fill until it gets to the hole.
The antifreeze is not difficult but a long process if you only want to use distilled water like I did.
G
GTSPOWERED
Ohio
I have all the fluids but the time and ambition. I guess that the time should not be hard to find with all the rain. this has put a damper on the driving time.
zeeshan_k24
