Eibach Pro-kit Lowering Springs
Tom Sessions
Hampstead,NC.
They are not hard to do. Remove the shocks and use a spring compression tool to remove the old springs and swap on the new ones.. Just remember to torque the shock bolts with the weight of the car on the suspension. Then a good alignment. Can do it with my eyes closed.
TCurtner
Townsend, TN
how hard are they to install?
Make sure you really want to do this, however. Though the car looks great (I have an 08), the handling improvement is debateable. I think the car actually felt more secure & planted (spirited driving and track work) with the original springs...I would love to have the factory 'feel' with about 1.5" lowering - these do not appear to do it.:dunno:
viperDoug
Mt. Airy, MD
I agree. I put these on my '06 and I wouldn't sayt he car handles worse or feels worse, but rather different. "Nimble" is the best way to describe how the car feels now. The car almost feels a little paranoid now. It does look great though! If you can swing it, install these with a coilover adjustable suspension like Motons and you will be very happy.
dragon rider
I like the ride. The car feels better in the corners to me. I to wish it was a little lower, but it is a good improvement over the stock appearance.
Chuck 98 RT/10
tampa, fl USA
Somebody better define the term "ride quality." IMO if we're talking about a sports car there is only one acceptable definition and that is, it handles better.
But if it's the type that drives with a latte in one hand and a phone in the other their definition might be more along the lines of soft.
Leslie
Indiana
I have them also, it does feel BETTER on a roadcourse, NOT as good on the street.
snakem04
Poconos Pennsylvania
I was thinking about getting myself a set of these springs. Is it worth it to buy a lower set of spring caps. Like the ones partsrack sells and are there anyother places to get spring caps.
BlackSnake99
Northern Virginia
Timely thread, as I just bought a set for my '99 GTS.
Chuck and Leslie, I am interested in your input...
I have been told that the Eibachs take you as low as you should go, because you can stay with factory alignment specs, and that caps are too much. True/false?
Second, I like a firm ride and am really interested in track handling. I'm not a 'latte guy' that Chuck referred to:D. Will the Eibachs be a step in the right direction? Motons etc. are simply not in the budget. Did you change the settings on your Koni's?
Leslie
Indiana
I bought rebuilt shocks and springs from John Archer, actually came from another GTS...Aaron from the Il VCA when he was parting out his car before he bought the ACR. I did a corner weight/alignment at a Viper shop in IL, along with a 'bolt tighting down' and tranny and motor mounts. Car vibrates a lot at the track and it's good to recheck bolts.
My car is low, challenge on the streets I will tell you BUT...when I got on the track?
oh my.....
that first lap, I had the biggest grin on my face!
car was turning in like there was NO tomorrow! ....like a different car for sure.
just lowering it from the springs I felt a difference.
Twister
good to hear Leslie..I have them on my 03 srt10 and was hopeing their was a good trade off for the rougher ride
Chuck 98 RT/10
tampa, fl USA
My street Viper has stock springs and shocks. Lowering it for the street just isn't a big deal for me.
My tracker is lowered 3/4 inch with Eibach and Penske. Generally if a car is lowered it will corner better. But there are a lot more variables for getting the best out of the suspension and it is a continuous journey.
vipergtsinnova
I have a set ready for install. Wondering if anyone has done an install with pics? I have the compression tool that I bought sometime ago for another car but never used it.
Spring install seems pretty straight forward, but I am a visual person and like to see it before I do it.
Anyone?
Black Moon
Knoxville, TN
I would never try it with a spring compressor 'tool'. You need a manual or electric strut/spring machine that you will find in a shop. You have to compress the coils too much to use the tool available at Autozone or anywhere else. The real deal has three adjustable load points or hooks on the lower and upper.
Bottom line, have someone do it for $10-$20 each and don't risk breaking your hand or finger like I did several years ago.IMHO!
ulllose
Brunswick, Ohio
Blackmoon is somewhat right.......... I did mine with the spring compression tool from autozone....it was hard compared to anything wall mounted or something more professional...lol But i was able to do it but put a good scratch in my stock shock becuase the tool wasnt hooking on right.
And one thing I didnt do was tighten the shock up after the weight was on the suspension, call me dumb but i couldnt figure out how to do that when the car was back on the ground and not on the lift.....anyone want to tell me??:D
Black Moon
Knoxville, TN
You tighten it before you lower it. Shock bolts affect nothing. I'm impressed you got them off with the Autozone tool. You are braver than I. I had one of their tools break and the broken piece hit my knuckle breaking the bone. It still hurts every morning. Never again. I now have many mechanic friends with proper tools for what I can't or won't do.
ulllose
Brunswick, Ohio
Blackmoon......guess I'm still not getting it......if I leave it on lift the suspension is hanging free......so in order to put the weight back on the suspension I had to take it off lift....
Figured I'm going with motons soon so I'm not to worried about that I didn't tighten it correctly but still curious
AbsolutHank
Odenton, MD
You can also just lower the lift to almost the ground, and then compress the suspension by jacking the lower control arm up with a floor jack, each wheel position at a time. It's essentially doing the same thing...
jimchris
I couldn't compress mine enough with my spring tool so I ran them up to a car shop. They installed for a few bucks and then I put them back on car. I lowered just for looks, my splitter is 3.5" off the ground.
KDR83
Tampa, FL
I realize this is an old thread, I love the lowered look....so caps and springs is too much for the stock shocks, if that is the case, what aftermarket shocks do people recommend?
AbsolutHank
Odenton, MD
Unfortunately, there aren't really aftermarket replacement shocks available. You have to step up to a set of coilovers, which start at $3000 for KWs, and on up for Penske's and Motons
351carlo
Northern Delaware
Re-reading this, I'm a bit confused. Don't the shock bolts go through a bushing from one side to the other? With a rubber isolator and then another bushing which holds that in, which on the OD is connected to the shaft? It's been a while since I did mine, but with this configuration, I can't see why anyone is concerned with torquing these bolts with weight on the car.
KDR83
Tampa, FL
wow that's intense, so can you get away with eibachs on stock shocks? what about springs and caps, I like my cars to sit pretty low but won't be spending $3k on coilovers anytime soon
No members online now.
JpKL
