Eibach's and Koni adjustment = GOOD!
Kurt 97 GTS
Dallas, TX
Eibach\'s and Koni adjustment = GOOD!
Finally got around to changing out the springs and adjusted the stock Koni's at the same time. VERY nice improvement in handling. Only regret is not doing this sooner...LOL!! :)
99 R/T 10
Enterprise, AL USA
Re: Eibach\'s and Koni adjustment = GOOD!
Any pictures of the job? Might want to think of doing a write up for the "how to" section :2tu:
jk
Richardson, TX USA
Hey Kurt, about time! You've had your Eibachs way longer than I have, and I have had mine on for months!
Did you check to see if you needed an alignment after the install?
RedEnuf93
Lancaster, PA
I told you so....
Yes, what was the diagnosis regarding alignment?
xcesshp
I just bought a 97 B/W GTS and my Eibachs came today. I will snap before and after photos and post. Anyone know how the springs affect the alignemnt?
K
Kurt 97 GTS
Dallas, TX
Boy, I knew that some of these comments were coming!! :)
I enlisted the help of a very knowledgable person, Rich Carlson to help with this project. To say that there was more to it than I originally thought was an understatement!!
I decided upon 1.5 turns up front and 1.25 turns for the rear shocks after much research. After the suspension was back in place, Rich took me through a time consuming process of bringing the car back to design height. A quick check of the suspension with an inclinometer (sp?) revealed everything was within tolerance. Suspension was then tightened and another check of the suspension (camber I think) revealed .25 % negative, which should be good and not wear the tires.
Car looks and handles so MUCH better!! I would highly recommend this modification - if done right :)
