Engine oil capacity
Simms
Pittsburgh, PA
Service manual says 7.5 quarts with the filter. Is this enough, or do I have to buy more oil?
Viper Wizard
South Salem, NY USA
Hi Ian,
August 1996 DC sent a correction sheet for the 96 GTS service manual,
page 0-2, to correct the type-O "7.5 qts" to 8.5 qts.
You need one more quart! :headbang:
Simms
Pittsburgh, PA
Hi Ian,
Thanks Chuck! You always have the answers. :2tu:
95Viper
Phoenix
Don't just throw 8.5 in there too. Put in just under 8 and start checking. You might get up to 8.5 but don't find out something weird and end up having to drain some out.
IEATVETS
Cottage Grove, Wis.
That is odd, why does my manual say the capacity is 9.5 with the filter? I change my oil 2 times a year and 9.5 puts it right where it should be.
A1998
Baltimore Ohio
Chuck:
Does that apply to only the 96's?? My 98 GTS says the same thing! (At least I think it does!)
A1998
Ron
Indianapolis
From memory, it's something like this....
1992 ~ 1996 GENI were 10 qts.
1996 ~ 1999 GENII were 8.5 qts.
2000 ~ 2002 GENII were 10 qts.
2000+ GENII oil pan fits all GENII engines. A common upgrade for any autocross / Viper Day student as the added capacity minimizes G force dry pickups.
Ron
Indianapolis
Slaughterj - you have a small error in your sheet. A multi-year service manual check confirms my numbers above including that the 10qt pan started in 2000 not 2001.
pdmracing - My guess would be the change was the result of several engines grenading at Viper Days events because of oil starvation.
potterb4
