exactly how much top end does 3:55's kill?
STUGOTS
NY/CT
exactly how much top end does 3:55\'s kill?
anyone know or test this?
Moundir
Ny
Re: exactly how much top end does 3:55\'s kill?
I hit 180-182 on my car with 3.55s so I guess ~8-10mph on stock car :) (well worth it, you will love the gears)
Mike
STUGOTS
NY/CT
well i have 70 mm tb's smooth tubes , filters and 1.7 rockers as of now but i plan on a roe charger
STUGOTS
NY/CT
is it true that the car can still do the same top speed but will get there slower from like 150 and up?
Moundir
Ny
No the car loses top speed but gets there faster, you have it backward ;)
Viperfreak2
Duncan, SC USA
Just off the top of my head, 180-182 sounds like a good top end for a stock GenII. Stugots might have a point that 6th gear becomes useable (all top end tests I've ever read on a Viper use 5th) and maybe the top end would be better? Theoretical top end in 6th of the SRT-10 is over 300mph. Give it 3.55's and ....ugh, too much math this early in the morning.
Joseph Dell
Atlanta, GA 30338
Drag racing, 3.55's make you have to shift into 5th.... Viper red-lines 3.55's at about ~118 mph.
Stock 3.07's red-line at ~140mph. So Does this matter? Depends on mods... My car will hit 140 in the 1/4 mile, so I try to stay in 4th. If I had 3:55's that would be another story...
JD
joe117
Maryland, USA
Hey stu,
The 3.55 is better because it lets you use the whole transmission on real world roads.
Even with the 3.55 you still get top speed in 5th.
You should get rid of the 70 mm tb's. They will only hurt you with what you have now.
Lots of guys want to put them on because it's so easy but it hurts the power. You will get beat by a guy with stock ones.
Put you old ones back on and really feel that power again.
Martin D
Dunwoody, GA USA
JD - the 3.55'***** redline at 135 MPH in 4th gear. (not 118) 3.07's are good to 148.
Regards,
Joseph Dell
Atlanta, GA 30338
Hum... Then maybe I'm mixing it up w/ 3.73's...
I redline 4th pretty good at 140, though.
May Martin - How would you know? Have you ever had your car that fast?
JD
Dr Roof
Louisville, KY usa
IF your car is heavily modded and your gonna drag race the 355's are not a good idea.
CHAD
Sarasota, FL
Unless you run a 28" tall slick! In fourth gear:
6000 rpm, 3.07 gear and stock tires = 148 mph
6300 rpm, 3.55 gear and 28" slicks = 148 mph
Now there's another wrinkle you didn't want to think about. :confused: :D :p
Chad
mntngts99
Boise, ID, USA
I have 3.55 and 575 RWHP and have never had to make a 4--5 shift in the 1/4. I think anything over 600 RWHP would need the 3.07.
JGK95
Chicago
You know who can answer this Very COOL question: None other than Paolo. Being that he's the resident ahem..counselor aka closed track coneseuir(sp?) I would consult his expertise in top end theory. EG. How many people know for fact that the mirrors outside of the car fold in at 175 MPH?? I know only one person!
PAOLO WHERE ARE YOU?? BRING YOUR THEORY AND MATH WITH YOU!
Jay K.
joe117
Maryland, USA
The mirrors fold in at 175mph?
What a POS, can't DC get anything right?
JGK95
Chicago
HAHHAHAHAHAH!!
Joe You Rule!
joe117
Maryland, USA
Someone could make a 175mph+ detent mod for the mirrors.
No more annoying mirror folding, money back guarantee.
JGK95
Chicago
Okay, I just hung up with the MAN aka Paolo. I had learned the following at http://www.f-body.org/gears/
With a 26.23 tire And @6200RPM with a 3.55 Axle Ratio
The ultimate top speed in 6th gear using a 0.5 gear in 6th equates to 184MPH.
1st...2.66
2nd...1.78
3rd...1.30
4th...1.00
5th...0.74
6th...0.50
Cheers,
Jay K.
CORRECTION: The Mirrors pop OUT not in My bad :laugh: oh!:
JGK95
Chicago
Joe,
What'd you get??
FE 065
MI
MPH=
RPM x Tire diameter
divided by
Gear ratio x 336
(Gear ratio by the way = gear ratio of whatever gear you're in x ring and pinion ratio)
RPM=
Gear ratio x 336 x MPH divided by tire diameter
Gear ratio=
RPM x Tire Diameter
divided by
MPH x 336
joe117
Maryland, USA
JGK95
I put 26.23" tire, 6200rpm, 3.55 gear, .75 5th gear, .5 6th gear. Into the calculator.
Top of 5th 182
Top of 6th 273
I think you must have read the 5th gear number by mistake.
garolittle
Augusta, GA
MPH=
RPM x Tire diameter
divided by
Gear ratio x 336
RPM=
Gear ratio=
RPM x Tire Diameter
divided by
MPH x 336
That would be fun to calculate after a few shots of whiskey. :D
JGK95
Chicago
Correction Found. Thanks Joe!
Jay K.
Moundir
Ny
JGK95
Top of 5th 182
Top of 6th 273
And you needed a calculator to tell you this lol ;) For all those intrested as well a near stock viper will not pull in 6th with the 3.55s, car just hits a brick wall :smirk:
V10 MOJO
Youngstown, Ohio
ive got a set of 3:55 to sell. i loved them and the only reason i went back to stock was due to my HP upgrades now too much for 3:55.
CHAD
Sarasota, FL
What? I have 3.55's in my car. Car hooks well on DR's and ran a mid 1.5 sixty foot on its way to a 10.3. I can't wait to get back to the track and push it a little harder.
With a 26" tall tire, you should be good to 135 or so in fourth. Do you think you'll break that with all motor? If so, that's great.
Chad
imflyinbiya
