MacManInfi
I have a 97 Viper with a 99 fan. The temps climb pretty high (almost to midway between 190 and 250) before the fan kicks on. The temps will instantly start to drop and they'll go down to just above 190 and turn off again. Doesn't matter what the temps are outside, if I'm moving slow in traffic, I see the same thing. On the highway it seems like the temps stay pretty solid, just above 190.
I was thinking that I wanted the fan to kick on sooner, but it seems weird to me that the fan should be able to instantly effect the temps unless the temp sender is in the radiator. If it is, then perhaps what I really need is a thermostat that opens at a lower temp?
Interestingly enough, I recently had my car at the dyno. We made two different pulls, the first one while the temps were at their peak, and then a second pull a few minutes later just after the fan had kicked off so the temps were at their lowest. You know what the difference was? 12rwhp and 13rwtrq.
-Chris
-Chris
