Finished the NOS System
Devin 97 Blue GTS
Miami, Florida
:2tu: Finished the NOS Systems, Dyno Time
Some pics of the install / sorry for the dark pics
(Beware, Valve Cover ugly)
Bottle
Wire Plate / Thanks Jack B.
Pump Boot
Nozzles
Fuel Pick Up
Purge
Switches
Gauges
RedEnuf93
Lancaster, PA
Nice set up, expecially the way you wired relays and RPM switch!
How much the fuel voltage booster pumps up the volts, 16V? Did you do the wiring to be activated from WOT switch or a separate switch?
Since you have the Fuel upgrade, it looks like you are going to be serious about spraying, post results if you go to dyno.
GTSnake
Motor City
Nice setup! What plugs are you running? How much timing are you going to take out?
MaxedGTS
Ohio
very nice install :2tu: how much more horsepower will you make with the nitros?
Max
FE 065
MI
I'm always tempted by NOS... but at Columbus a lot of guys were having NOS troubles. They weren't hurting any parts, just couldn't get it to work perfect everytime. One guy had ice on his bottle cooling it off after being in tech too long, another guy's set up had worked great repeatedly on the dyno, yet he was having tecnical troubles at the track, and the NOS-savvy owner was ready to give up on it and run n/a.
D
Devin 97 Blue GTS
Miami, Florida
Keep simple is the name of the game;
The following is the list of equipment and vendor.
NX Wet Nos Kit (Summit)
NX Gen 2 upgrade (Summit)
NX Bottle Blanket (Summit)
NX Remote Bottle opener (Summit)
NX Jets (Summit)
MSD RPM switch (Summit) (switch sent to MSD to mod for a viper)
MSD Pills (Summit)
MSD Boot an Pump (Summit)
NGK ZFR6F-11 spark plugs //gap 33// (Summit)
Extra Nos SS lines (Summit)
Switches, connectors and switch box (Radio Shack)
Add a fuse and fuse link (Auto Zone)
Auto Meter Fuel Gauge (Summit)
Auto Meter Nos Gauge (Summit)
Gauge Pod (Elite Motor Sports /Scot)
1BADSNK
Jacksonville,FL.
Have you dynoed your setup yet?
Hey VIPER D:
What were your RWHP/RWTQ #'s again on your NOS/Propane setup? What mods do you have on your car? What was your air/fuel ratio?
PRVT JET
streamwood, il usa
Devin, Have you seen or tried the MSD digital rpm switch? That one does not need to be modified. I just ordered it and will see how it works, it's all digital so it doesn't need any rpm modules to mess with.
