Front Fascia Install
SuperSaiks
Looking for instructions/how to guide/video on how to properly reinstall the front fascia so that there are no gaps below the headlights etc.
Has anyone made such a tutorial etc, would be great if you can post it
Matt M PA
Langhorne, PA USA
Most don't put the fasteners back in under the headlights and when it's hot....you get the gaps. There is really no (or very little) adjustment. In my opinion...it's important to put all fasteners back or you'll have gaps. If memory serves, we used a bolt and nut in the under the headlight locations as we couldn't find a way to get leverage to push the clips in...in this location.
pollard4286
I'm having the same problem. I can see the fasteners under the headlights are not fastened. Do I have to take the headlights out to get to these fasteners?
8.0L>1.8T
This is why I'm scared to death to pull my front fascia off: I don't have any gps now and I'd hate to have any when I put it back on..
WSAYERS80
Orlando, FL.
I have had mine off several times. To install the fasteners under the lights I disassembled an old pair of pliers with a rubber grip. The curve of the handle gave me the angle I needed while the rubber plier grip help grip the fastener and kept it from sliding off. I then centered it on the fastener and used a hammer to gently tap the plier handle pushing the fastener down.
Hope this helps.
xeng yang
