front wheel hop
compcoupe21
Quick question. Yesterday I took my car out in 20 degree weather. At one point in a parking lot I had to cut the wheel hard to the left and slowly inch past someone who couldn't drive. While doing this I noticed my right front wheel felt like it was hopping, almost like I had a flat or it was riding on the edge of the rim. When I had a chance I tried it again and also in the opposite direction, same thing. Is this normal, was it due to the cold or do I have a problem? I only have 332 miles on the car so I'm guess the car is fine for I bought it new and it hasn't hit a curb, *** hole etc. Any feedback would be greatly appreciated. P.S. It's a 2006 coupe. Thanks
C
compcoupe21
Re: wheel hop
Could have scrolled down a few posts.
Thanks Austin, but their is a difference between the front wheels and the rear wheels... :bonker:
johnk
Laplata, Maryland
Re: wheel hop
Compcoup21, any signs of the front tires rubbing when at full lock in either direction? Car lowered? Good luck..
C
compcoupe21
Re: wheel hop
I wouldn't think so John, going full lock to lock shouldn't allow rub and the car is bone stock. The car came to me via enclosed trailer but I checked the tie downs before he unhooked and they were at the factory hold down points.
Maybe it's rotation hop (one wheel spinning more the the other), I'm not sure and that's why I'm looking for some feedback. Appreciate yours...Dan
Grunt
The Lone Star State
Re: wheel hop
At low speeds with wide wheels you will feel a chopping in the front as the tire slides through the turn. It happens in all weather types.
So, it can be normal if its what I discribed.
Austin
Clear Lake, TX
Re: wheel hop
Sorry, didnt read the thread, just noticed it had the same THREAD TITLE as yours. Its obvious Im not the only one who didnt read the thread before making a post. :rolleyes:
C
compcoupe21
Re: wheel hop
That's sort of what I was hoping to hear but wanted to get the Viper community feedback for it's the best way to get knowledge about your ride!
Thanks Grunt and it's cool Austin, my bad!!!
viperjim
Maryland
Re: wheel hop
My "03 does the same front wheel hop/thump only if the front wheels are turned to the extreme. When I back out of my garage I always notice it. At first I thought it was the posi unit's clutches unloading but later attributed it to the front wheels. Glad to hear its "normal".
Jim
29OUTLAW
Solomons Island, Md.
Re: wheel hop
I feel weird stuff when I turn sharp a low speed. It could be the fact that the front tires are so wide that one side of the tire has to travel farther than the other side so it "hops" to catch up.
twinturbo3150
Re: wheel hop
Jim
that's funny mine does it as well when pulling out of the garage and locking the wheel to the left, I fell like the front is slideing a little.
Austin
Clear Lake, TX
Re: wheel hop
Check your PM's.
Racer Robbie
Guilford, CT-USA
Re: wheel hop
the run flat tires take a real long time to come up to temperature, longer than the Michelin NON Run Flats. I would try running 32 psi all around if you are running run flats. I found this works out real well on the street. If you have Michelin NON Run Flats I have found that 34 front and 30 rear is great on the street
