Fuel Injector Set w/Connectors - 92-02 Vipers - 60 lb/hr @ 55 psi - Air & Fuel Delivery - Roe Racing
Are your stock injectors not putting out enough fuel for your supercharged, turbo'd or head & cam engine? Worried about running lean and hurting your engine? Here is your answer! Don’t spend thousands on new fuel rails and top feed injectors when these side feed injectors are rated for 60 lb/hr at 55 psi (stock fuel pressure). Sold as a set of 10 injectors with connectors.
Price: $740.00
Product Details Until now, if your 1992-2002 Viper engine was putting out serious power, your only solution for bigger injectors was to add an expensive set of fuel rails and install bigger top feed injectors, typically at a cost of around $2000. This replacement set of side feed fuel injectors have been modified to fit into the stock 1992-2002 Viper intake manifolds. These are rated at the stock resistance of 12.5 ohms so an additional “load box” will not be needed. We also include new fuel injector connectors with metal clips that are far superior to the stock, all-plastic clips that often became weak over time loosing their electrical connection. COMPARISON : GEN1 stock injectors are rated at 25 lb/hr @ 55 psi and GEN2 stock injectors are rated at 29 lb/hr @ 55 psi. NOTE : Tuning will most likely be needed to obtain maximum horsepower output when adding these injectors. Picture shown of single injector before modification.
Price: $740.00
