Fuel pump module change
Viper Wizard
South Salem, NY USA
Good morning vettlag, ok that's the fun one to do[fuel filler vent tube] the hose has an elbow on the end that your looking at.The elbow is pushed throw a rubber gromet in the fuel pump module. Carefully with a screw driver lift up a corner of the gromet and spray it with WD-40 to lube gromet. Pry up gromet and elbow to remove.[Caution It's just plastic be carefull!!] When you remove the module from the tank you will have to tip It backwards to rear of vehicle and It's full of gas! Some will spill!! Use a drain pan&lots of newspapers to catch the fuel! Hope this helps?
bogzie
