fuel surround rubber on GTS
FLX109
Massachusetts
Has anyone had to replace the rubber around the fuel door on the GTS body? I am wondering the best way to replace it as it looks like it is pulling away a little bit and wondering if it is a easy fix, is it glued or just set in?
thanks
Smokin' 2
The Woodlands, Texas
I'm starting to notice this issue as well. Sorry I have nothing to help but look forward to hearing from those that have addressed it.
96GTS
Dyess AFB, TX
I'm doing mine right now. Be sure to prep the surface by washing all the dirt and gobble-dee-goop off with warm soapy water and rinse well. I'm going to use an old tooth brush to get in the hard to reach areas and give it plenty of time to dry. My gasket has shrunk a bit, so I'm going to set it out in the sun for a while to make it a little more pliable.
