Fuse for the windows
viperdoctor
Houston, TX USA
Does anyone know which fuse is used for the power windows on a 2001 GTS?
The owners manual has all the fuses listed, but there is no mention of the power windows.
I would like to use this line to power the radar detector.
Thanks,
ViperDoctor
Viper Wizard
South Salem, NY USA
viperdoctor, The power windows on your 01 GTS are on a 30 amp circuit breaker behind the fuse block.
Why dont you use the lighter circuit fuse #20 15 amp? It's all by itself, you'll be safer there!
Hope this has helped.
V
viperdoctor
Houston, TX USA
Wizard: Thanks for your message. It helps a lot!
I think the lighter circuit is live all the time. I want the radar to turn off when I take the key out (ignition).
As long as you stay on the right side of the fuse, there won't be a safety difference?
ViperDoctor
