coupe
I've searched, but didn't find this problem...
Car is a '96 GTS.
Parking lamps and headlights are working perfectly, but the gauge lighting is not coming on. I thought it might just be the dimmer switch on "dim" but it's not changing the illumination at all. It all worked fine yesterday and the only thing I've done in the meantime is I took center console out for a shifter change and in doing so, I disconnected the window switches, rear defrost switch, and cigarette lighter plug. Everything was put back as I removed it and they all work, but now the gauge lights won't come on. Gauges themselves are operational, but no backlighting. I've checked the 4 amp fuse and it's intact.
Any ideas? Is there a ground for the gauges that might be near the console that could have come loose? Thanks for any help.
Car is a '96 GTS.
