Gen 5 turning radius
slysnake
Step on the gas and let the rear slide a little. Turning radius problem solved. ;)
Paul Hawker
San Diego, Calif, USA
Going to be difficult.
Our Vipers have huge engines, and equally huge tires. Combination usually results in larger turning radius.
Miata's have tiny engines, and tiny tires, and much smaller turning radius.
hou99gts
Rosharon, TX
Zero percent chance IMO, if anything we need more front tire, and that doesn't go with big engine and tight turning radius.
TrackAire
Vacaville, California
The Gen 5 will be able to use its electronically controlled limited slip diff and its ESP program to lock up the inside wheel and power the outside wheel exclusively at speeds below 8 mph so it can make turns approximately 30% tighter than the Gen 4 cars....sorta like a cutting brake on a dune buggy.
At least that's how I would program the computer system :D
Cheers,
George
albourassa18
