GEN I engine rebuild issues
tristan rizzi
Pensacola, Fla, U.S.A.
Help,
I am having my 94 re-built by ESI engines in San Diego (they make winston cup engines) and I was wondering if anyone knew what the 23 fixes were for the GEN I engine. If anyone has a site that details these corrections, or someone I could call it would be greatly appreciated. I want to point out these issues so they can be checked as motor is worked....
Thanks for any help offered.
Tristan
Jeffersonville, IN, USA
Just got my engine back from Arrow. It is being installed now. Here's the list:
GEN1 Arrow rebuild:
!!! AS NEEDED !!!
1> crank shaft
2 New windage tray 1995 and older
3 Oil pan
4 Push rods
5 Lifters
6 Timing Chain
7 Cam
8 Crank gears
9 Cam shaft
10 Front cover
11 oil pump assembly
12 Rods (connecting or push or both?)
13 Pistons
14 New cylinder liners
15 Re-manufacturing of heads
16 All seals and gaskets
17-18 Spark plugs plug wires
19-21 All cylinder block specifications such as..line bore,replacement of cam bearings, and any other machining or modification necessary to bring the motor up to specifications.
22 The motor is then dynoed for two hours for horsepower check, put back in the box and returned to you.
Mando9595
