As previously discussed, a trim shop ruined my Headlamps. I have since removed my headlamps and purchased the new lenses from Viper Outlaw. He has been very responsive and great to work with. I am having his source, Ryan, take off the old lens, and replace with the new Viper Outlaw Lens. Unknown to me, a novice on these things, these lenses are not Polycarbonate. They are a softer resin. Which is good in some ways, bad in others. Because I take care of my cars, and because this car won't be driven except on nice days and evenings etc., I think I will be OK. Does anyone have experience with this? Ryan has been wonderful as well, making sure that the lenses are properly installed, clear and will put a Ceramic coating on them. For now, this seems to be the ONLY option for those of us with cracked Headlamps. Here is what Ryan sent me for discussion with regards to keeping them clear and scratch free:
"Using PPF on them is debated, they are resin, so they are not as durable as OE polycarbonate, polycarbonate is prone to crackle and craize though. If you put thick ppf on the OE they actually can develop white burn marks in the beam areas. The polycarbonate can't cool off through thick PPF. We assume resin will have similar issues but instead of burning white marks it would most likely deform slightly. It is however softer and easier to buff, and likewise scratches easy. A thin PPF like normal clear vinyl would probably work fine, I would not use Lamin-x, laminx is about .10 thick, almost as thick as the lens itself and most of the cooked lens I have swapped had it or something similar."
If anyone has experience etc., let me know. I am excited to get these back and get the car back. I am repainting the side sills and the front and rear Facia. The car will be beautiful when I am done. Already drives and rides beautifully with all the work we have done.
Thanks,
John
Thanks,
John
