Gen1 Speedometer is Broken
RAWV10
Gents,
The speedometer on my 1995 RT/10 (22K miles) suddenly stopped working last Saturday (Oddly enough just after I was pulled over/recieved a slow down speech from officer friendly!).
The speedometer unit still lights up /odometer is not working/all other electonics are working correctly (turn signals etc.)
Car does not have the radio /speed compensating control volume control (original cassette stereo).
I have consulted the Dodge shop manual (will check speed sensor and wiring harness)
Any other ideas or words of wisdom as I work through the issue are much appreciated.
R
RAWV10
Update - I deep charged /conditioned the battery and took my viper on a test run. Still no speedometer/odometer readings.
What now?
Mopar Steve
Newark DE
In order for it to re-set, you must drive the car so that the needle reaches top speed and returns to zero!
99 R/T 10
Enterprise, AL USA
Call Chuck Tator at 914-763-3136. It may just be the speed sensor in the transmission that has failed. If it is the sensor, it will be an easy fix.
R
RAWV10
Steve,
Will do - I love to run my car up to speed!!!.
My viper has apgraded headers/exhaust/ upgraded intakes / throttle bodies = fun!
jdeft1
Metropolis
Gotta admit, I like Steve's method..... !! lol
But probably a bad sensor.
R
RAWV10
Update-
I ordered a new speed sensor (consulted the shop manual - ran the Part # down etc.). Removed the current speed sensor from the drivers side of the transmission and compared to the new sensor. They do not match - old one is smaller in diameter and is flat on the end that gets inserted into the transmission / replacement is larger diameter and has a small spindle shaft coming out of the end that gets inserted into the transmission.
The part # I recieved matched the Part # I got from Dodge parts website.
What am I missing here? was 1995 a wierd year for transimmisons / sensors?
Any ideas on how/where I could get the correct sensor?
speedracervr4
Lancaster, PA
Did you use the vehicle Vin # when ordering the part? Maybe they changed sensors mid year? Might want to call Chuck and see what he thinks.
95Viper
Phoenix
I hope you get this before you order a new sensor. I have an extra one in my garage. I only had a few miles on my 95 and the speedometer started bouncing to zero and dying at times. I thought the speed sensor so bought one and replaced it. Did not fix it. Ended up being a bad PCM which cost me $400 or so if I recall.
R
RAWV10
Thanks to all for your 'sage' advice and comments.
My speedometer is now working perfectly. It came back to life as I was driving back from a car show this past Sat morning. The following is a recap of my repair efforts and insights (ISO of anyone who runs into the same speedometer problem):
- I consulted my 95 viper shop manual
- pulled the speed sensor (was a small diameter - round - flat ended unit (no spindle) - had the words 'micro switch' imprinted on it. (also checked transmission fluid level = good thing to do as the plug is near the speed sensor)
- As I am not the original owner of the viper - I also checked for aftermarket diff gear (contrary to my previous posting - the car has 3:55 rear gearing). The speedo is accurate (per my GPS) and I now assume that the car has the compensation kit installed.
- I traced all associated speed sensor and speedometer wires and splices (shop manual does a great job laying ou the electrical wiring harness) - no issues
- I checked all fuses - no issues (I did notice a thin wire running across the fuse box / fuses - connected to a screw that appears to hold the fuse box to the chassis - wire is spliced into the wiring harness closest to the fusebox) - ANY IDEA ON WHAT THIS WIRE IS OR MAY SUPPORT?)
- performed battery deep charge and condition cycle (using my PULSETECH brand battery charger - great compact charger that I highly reccomend - We (USMC) use them to support our vehicle in long term storage aboard ship and storage sites around the world).
R
RAWV10
AAAGGHH ! Speedometer is now working intermittently (perfectly) - every other time I start/drive the car. Maddening. I am begining to think that iti is the PCM. Any more help and advice is much appreciated.
Also - on another note - I am more than willing to trade gen1 interior finishing advice (as I redid my interior in the original factory quartz color and maintained the original matte black gauge surrounds) for speedometer advice.
cheers,
Pete
No members online now.
wesleyCrowbar
