Golden Collection of Viper Tricks, Traps and Lessons…
white out
The Mitten
Yes, Chuck explained it to me that doing this will dump EVERYTHING in the car's PCM and will allow the Viper to relearn from zero. Viper PCM's are adaptive and always "learning" as we are driving. After a while, the PCM gets full of "cookies" and thats when the drivability issues arise. Doing the positive cable-to-frame grounding is just like deleting all the cookies in your web browser's memory. After doing this, be sure to insert the key, turn to "on" (do not crank) and press the gas pedal to the floor firmly twice. Then turn the key off. This will reteach the TPS the position of the pedal at WOT. You can now start the car as normal.
Can you do this from the remote terminal (under hood)?
Nick
NO !!! Unless I'm missing something, your plan would create something akin to an arc welder.
You must kill the current to the PCM...either by exposing the battery itself and removing the positive cable from the battery, then grounding that cable for a couple of seconds...OR...unplug the PCM connections at the PCM...noting that while many have done it this last way, the Manual says to disconnect the battery cable at the battery BEFORE you unplug the PCM.
97snk
BATTERIES--Vipers have lots of funny drivability issues when the battery is low/bad. If you're battery hasn't been replaced in 3+ years, its a very likely candidate. DO NOT replace with an Optima Redtop. Even Vipers driven 10k/year kill Optimas in about 6 months
WHAT? :omg: I just got a red top for my GTS, thanks VCA for the great discount on optima red top that won't even last me 6 months...:(
white out
The Mitten
Okay, I was thinking that it would be an interesting experience. Thanks for clarifying.
Nick
Jack B
NE Ohio
I would just disconnect the remote battery terminal under the hood and reconnect it, then set the WOT. It's easy enough to do.
There is a problem with removing the cable under the hood. It is very easy to spin the stud when you remove the cable, when that happens the power module is scrap and not repairable - $$$
vigilantty
Clarks Summit, Pa.
TATOR – Is not a Viper God, he is a man like you and me, he is an extremely talented and caring Viper expert, nothing more....
WRONG!!!!!!!!!!! Chuck is the original viper GOD!:headbang:
[media]http://www.tatorsdodge.com/images/86tatorsbbq5-med.jpg[/media]
Vic
I always use old oil to lubricate the new filter seal. Never had any problems, no leaks, no frozen filters, no problems whatsoever in over 1 million miles cumulative, between various cars I've owned over the years. A few have approached 200,000 miles each. I call b.s. on that one.
kyleblix
Portland, OR
thanks for the bump, great info here! Where should I take the car to address the door sagging issue? Body shop? Or should I take it into Dodge?
Ron
Indianapolis
I'd learn how to do it yourself as you'll be doing it a lot. Not hard, but easier with two people and patience. Just be careful while test closing. Alternatively, a high end body shop would be my choice versus a dealer.
emaw
I am a new owner and there is a ton of great information in this thread!
Thanks!
Damn Yankee
The Great North
These seemed to have all aged well. Amazing the passage of time. Engine still looking good...
There is a breather vent, at the forward end of each valve cover. It routes into the incoming air box. During heavy braking, some oil may slosh forward, into the intake plenum, and this will make very embarrassing big blue clouds of smoke. People will think your engine blew up! What you need to do, is to take the hoses from each valve cover, and route them to a small oil catch tank, that you can possibly mount to the aluminum cross brace, just in front of the engine.
There is also one more hose, right under the throttle body, that can allow oil to enter the intake plenum. I'm not sure what racers do with this one, but Dave Cawthorne on this site has a fix for it. He sells under the name "Dave's Big Brakes"
I have proven Pargraph 1 (intake oil) to be mostly false and I killed a fresh build because of using the referenced procedure.
The nip ples on the valve cover fronts are for Clean Air Intake to the crank case. Running a catch can here adds restriction and will cause the oil puking issue to worsen *significantly.* If run at high load (track) conditions, the vent hose from the Crank Case Ventilation cavity nip ple near the back side of the T-stat housing will load up with oil blowby, su ck past the PCV valve or orifice tee and into the intake plenums behind the throttle bodies. I have lost almost 1 quart per session at Road America due to this.
Under heavy braking, sheets of oil slosh against the throttle body blades and run into the airbox - soaking the air filters and drooling out the drain tubes. Under high-G turns, one plenum or the other will sheet flow liquid oil down the runners to the opposite bank past the intake valves. This oil will flood the cylinder rings and walls killing compression, foul your plugs and cause heavy smoke out the exhaust.
The place for a catch can for moderate use is between the CCV outlet hose and the inlet tee feeding behind the TB's. For more frequent hard driving/HPDE I recommend blocking the CCV hose completely. Use the passenger side valve cover nip ple to vent the blowby to a larger catch can and back to the PCV or Orifice tee feeding the manifold. Check the catch can regularly! If you still have heavy catch can accumulation, run bigger inlet/outlet hoses and connectors to the valve cover tops. AN 8, 10 or 12!
Damn Yankee
The Great North
My response would be as follows.
In the world of racing that you're referring to, one will have to take into account the extreme g-forces you describe.
In the more typical situation, using the described diameter feeder lines and the mounting position, there is no issue. Using a can with a sight glass and looking at it is also recommended. Over thousands of miles one would see a couple of ounces,if that. All of that is drained off at an oil change.
Thank you for taking the time to add your experience to the thread. It's all helpful.
Damn Yankee
The Great North
Hoods should open easy and close smoothly.
Yesterday I cleaned and lubricated all the points of the Gen 2 hood. Huge difference. One wants to removed hardened lubrication remanents and lube with white lithium grease.
1. 1 lever release, front fascia. Clean and lube latch and loaded springs. Nice clean pop-up now.
2. 2nd lever, final release. Took some time to clean up and lube. Remember to slightly lower the hood when sweeping that lever over.
3. 2 springs centered in the major hood frame structure. Once cleaned and lube, huge difference.
4. The rear two on frame side hood guides and glides. Wow what a difference when one lifts the clam shell up it smoothly comes right up no grabbing and once up, stays there. One hand operation again.
Lastly the closing push down is super light and lockup force is so much less. Just an on fingertip press 1/3 of the way back and snap! Lockup. Big improvents all around.
ViperTim
Sweden
I have always heard to NOT lubricate the hood springs because that will let it fall down when in open position. Not enough friction to hold it open.
GTSGEN2
Sweden
This happened to me. I was lubricating the hinges to make it easier to open, but that just caused it to fall down by itself. I cleaned the lubricant off with brake cleaner, and now it stays up.
