MAMBA
As I mentioned in another post I have removed the side exhaust covers to repaint as well as the front fascia. I noticed that the foil heat insulation inside the cover is held in place with aluminum rivets. The heads of the rivets show from the outside, both top and bottom of exhaust cover. Is this correct? I wouldn't think the factory would have rivet heads showing from the top and bottom side. Even though they are painted they are obviously still quite visible. If this is not correct, how should the foil heat shield be held in place.
Once again thanks for everyone's help.
