Check with Tom Welch, JonB, or whoever you're buying them from. I was informed that putting the heat shields back on top of my Belangers was not recommended and may void the warranty.
I also put the heat shields back on. Hated to cover up the nice look. As far as warranty I would rather ruin the headers than overheat the area around the headers.
Got mine from Jon B and he said not to run shields but if I was concerned I should call Belanger. Called Belanger and said not to run shields as the extra heat would be bad for the headers. No problems without shields.
My suggestion would be if you choose to leave them off make sure you protect your pressure bottle hose (Under Bottle). Also double and triple check your power steering bottle cap!
I thought I'd read here somewhere that heat shields MUST be used to avoid severely increasing your chance of underhood fire... Not worth the risk IMHO.
