Thanks Dan.
I hear ya, but I'm going to do the braided lines.
There are (2) "guides" for the heater core lines in the truck that will take care of the bends and routing.
I'm not doing SS braid though. I think the truck weighs enough in front (heh heh), and with the diameter of -10AN lines, these won't be just a few ounces.
I'm using the nylon braided lines. Much easier to work with (cut, fittings, etc), and a significant weight reduction over SS.
In place of the faux-AN clamps, I found this cool type of clamp from Gates:
Thermoplastic Clamp Offers Maintenance-Free Hose Connection - Clamps - Products | Gates Corporation
It's a thermoplastic piece that 'clamps down' when heated up, kinda like really heavy duty heat-shrink.
The nice part is that they look pro (save for the bigass GATES logo on them), and are easy to attach with a heat gun. No knuckle-busting!
The downside is that they are a one-time use clamp. If you want to take the clamp or hose off, you have to slice through the clamp. Bummer, but at less than $2 each, I'm not too broken up about it.
I'm doing a DIY article for another forum regarding replacing all these hoses. If you'd like a link to it or the info on what parts/connections/dimensions are needed, let me know. I'm happy to pass along the info.
