Help with sensor/switches on 1992
nautoncall
I need help identifying which sensors/switches these are and what's the part number to replace. I have a terrible oil leak from the end of this switch. I guess it's either the oil pressure sensor or oil pressure switch. It has one single yellow wire coming out of a rubber plug on the end. I can push the rubber plug back in but when I start the car the oil pressure pushes it out and the oil drips excessively. Thanks for the help. I have a video if anyone needs it.
Single wire will be the switch NOT the sensor. And it is 3/8 npt thread.
I can't remember off hand the location in the picture which is which.
N
nautoncall
Thanks everyone. Actually the single wire is the small thread. The 3/8 is 3 prong.
If it is the small thread then it is the pressure sensor.
You can test it by unplugging it and seeing the gauge pressure and light.
