Help with torque specs.
99 R/T 10
Enterprise, AL USA
Was looking for anybody that can confirm the "upper trans to bellhousing" torque specs. I do have a service manual and I just don't see them. Any help for the community? I just finished the clutch and put the tranny to the bellhousing and it is these bolts I'm not sure of. TIA,
FE 065
MI
My 2002 manual says:
trans to eng bolts (3/8"), 30 ft.lbs
trans to eng bolts (7/16"), 50ft.lbs
Is that what you need?
99 R/T 10
99 R/T 10
Enterprise, AL USA
Nope, that is the bellhousing to engine bolts. I have those, easy to confirm because the top 4 bolts at 3/8" and the bottom 2 are 7/16". I need the trans to that same bellhousing.
FE 065
MI
Ok, well... under (transmission) installation it says:
Install upper and lower transmission bolts, tighten to 30 ft lbs
Howzat?
No members online now.
JpKL
