Easy.. Just take off the plastic clips between the hood and the fasica, then unscrew the bolts in the fenderwell lips. Then alls left are the bolts on the bottom and your done. no need for instructions, it's that easy.
hoped that helped
Gerald
Let me give you my expert opinion...Gerbil is just an amueter! (mispelled!)
There are several plastic round tabs on the top side of the fascia I think 8. They are round black tabs that are push in type with a tree type retainer., You will need some type of trim fork or a large flat head screw driver to pop them off. Depending on the shape of them, you may need to get new ones.
There are also 4 of the same round tabs under the fasica by where you pull the lever to open the hood.
On the fenderwell side, you have 8 mm bolts to take off on each side.
Underneath you have lower fascia bolts that need to come off also. (I think 11mm)
Now this is where you may need a 2nd pair of hands so you don't rip off the turn signal bulbs and fog light connectors. You will see when you do this.
Have the helper hold the middle of the fascia while you pull one side of the fascia off the fender well and do the otherside. When that is done, disconnect the harnesses and it's off.
Just a side note, it will be easier to do if you remove the hood. Less chance of breaking something and scracthing the hood. there are only 4 bolts (13mm) holding the hood on. Don't worry about miss alighnment because there is no way for it to be crooked if you don't mess with the hood support cross member and the hood latches.
Hope this helps. Nevermind my typing!
