how do my spark plugs look?
Darth Menace
Edmonton, Alberta
Just changed them out. I dont know how many miles were on the old ones. They were autolite XP's oddly enough. Anyways just wondering if they look normal or somewhat messed up in some way
xRUSTYx
Nashville, TN
They look good ... Actually a bit on the cleaner side except top right and bottom 2nd from the right.
Gapping looks intact for the most part :)
Did you do a leak down test while you were at it?
DrumrBoy
GA
They look pretty good to me....were you having any noticeable issues or just routine changeout?
AZTVR
Chandler AZ
Leakdown Test
Good Test to figure out the health of your engine :)
Agreed that it is a good health check if you are having some symptoms; but, a major pain to do on the Viper if you are not someone that does it often. Finding TDC on 10 cylinders is a PITA and getting a wrench down to the crank bolt and turning it repeatedly and stopping in the right place ain't easy either.
(I did do mine and the good results did give me some peace of mind.)
D
Darth Menace
Edmonton, Alberta
What's the gap measurement? looks too big to me.
im not exactly sure what they were. I threw them out so i cant measure. keep in mind i dont know if you can see it from th pictures, but there is a teeny little spark thing....which might make the gap look bigger than normal
the new ons i gapped to .035
D
Darth Menace
Edmonton, Alberta
You might consider getting your injectors cleaned and flow tested as well.
im making a list of things to do over the winter season. Cooler thermostat, engine/tranny mounts, maybe get the intake/heads done (i doubt it, because im not confident in my head removal skills)...I should add the injectors to the list. They seem nice and accessible for sure
bluesrt
if it aint broke,dont fix it- i put a 100k on a engine and never touch the plugs
Johndirt
