How do you guys launch your high H.P. S/C'd cars ?
twinvipers
Raleigh,NC
How do you guys launch your high H.P. S/C\'d cars ?
Just bought a DLM car and wondered what rpm's you guys launch your cars at the track. I know each car is different depending on tires and HP, but wanted an idea. My nitrous car I think is different since I don't spray until second gear.
Vic
Re: How do you guys launch your high H.P. S/C\'d cars ?
I think they rev it to around 3000, and feather the clutch engagement. The rpms keep the car from bogging, and feathering the clutch controls the wheelspin? I think you need a special clutch.
For a relatively stock car like mine, I just let it bog off the line, since I'm no good at controlling the wheelspin with the throttle, and don't wanna waste my clutch. Don't drag race anyway (you can tell, huh?), and prefer the road courses.
SUN RA KAT
Guest
I hold the revs to 1500 and work the clutch and the throttle moderately fast - like I was at a stoplight and doing street racing. I don't get to full throttle until the end of 1st gear or the mid point of 2nd gear depending on how slick the track is. I get no bog, but traction is always a problem.
utahviper
Utah
Get some good tires, BFG's and heat them up and let her rip. Bring up to 3000rpm and ride the clutch out of the hole. Should be good for 1.6x 60' time or better.
Joseph Dell
Atlanta, GA 30338
With BFG's, I found that ~3000 or ~3500 I could launch hard. @4200 forget it... lots o' spin.
I was trying to find the sweet spot for my 850rwhp beast... and I'm pretty sure 3500 was it.
Tire pressure will also have something to do with it. I thik I was at 18psi on those runs.
Good luck!
JD
T
twinvipers
Raleigh,NC
Thanks for the help. I'll keep you posted when I get to the track. It's a beautiful 9 degrees here today. Hopefully in the next few weeks it will get above 30 and I will go.
T
twinvipers
Raleigh,NC
Will the stock clutch hold with slipping it out of the hole ?
Joseph Dell
Atlanta, GA 30338
I never had any trouble with 700hp slipping. But when I made the move to 850, we replaced the cluth with a non-stocker.
I have no idea if it would have held...
JD
T
twinvipers
Raleigh,NC
JD,
What clutch do you have ? Any changes in driveability ? Noises ?
Dr Roof
Louisville, KY usa
Twin Vipers
Launch is depending on your Tires! Alot of people will launch at high RPM sometimes it is better to hold them RPM down. Track COnditions and Tires make the difference here.
Clutch Many High HP cars run the stock clutch with no problems. I think alot of it is your driving skill and how many times you take the car to the track. couple times hear and there your stock will be fine. more than that look into an aftermarket Clutch.
Joseph
SEE YOU IN FLORIDA RIGHT???? :headbang:
Joseph Dell
Atlanta, GA 30338
My clutch is the carbon / carbon. I don't recall who the manufacturer is, though.
No problem with drivability. No noise either.
David - FL isn't looking to promising. I just got word yesterday that I need to be at a work conference that weekend. And it isn't in the continental US. So I'll be (quite unfortunately) missing this event.
But I promise you that NOTHING will keep me from the KY event.
JD
Moundir
Ny
Hey Twinvipers you bought Doug's old car? Dude you are only an hour away from me, we gotta get together :)
T
twinvipers
Raleigh,NC
I will have the new wheels on and ready to go soon. Have you ever gone to OBI on Sunday mornings ?
E-Mail me at [email protected]
StoleIt
get a nice aftermarket clutch, nice drive shaft,a nice big rear end, and some slicks. then launch off of the rev limiter and lift the nose....atleast thats how us GM guys do it.
T
twinvipers
Raleigh,NC
I doubt your launching the Camaro off the rev limiter.
Catwood
Not on a corporate rear end.....well, not twice.
StoleIt
lol, no not with a stock ten bolt. a wet noodle holds up better than our stock pos. no like a 9 inch strange rear, something nice a beefy.
Catwood
I had a currie 9" in my TA with 3.73.
This weekend we'll see how the Viper Dana holds up....
Carl
