How do you replace the bulbs on 94 Viper?
splochocki
Does the back of the headlight come off? Just remove the wing nuts?
Do you have to remove anything else?
Tom F&L GoR
Wappingers Falls
Yes, the back comes off, but if it's the first time, the sealant has dried hard and you'll have to coax it a lot with a screwdriver to pry it off.
Rollin4
Anacoco, La.
I wish it was that easy. First remove the three plastic screws on the top of the front fender wells, then remove the bolts that hold the panel on the front inside fender wells towards the headlights and remove the panel, then remove the wing nuts on the back of the headlights.This will give you easy access to the lights. Check headlight operation before assembling everything. Close your hood slowly after putting it all back together, check clearences. Some people may be able to due it by removing the covers on the back of the lights, but I didn't have any luck. You may want to align your headlights while your at it.
