This is probably the EASIEST thing to do on a Viper, or any car for that matter! Go to Wal-mart, and buy the kit that comes with three cans of refrigerant w/oil, quick disconnects, and pressure gauge.
Turn on car, with a/c fan on full blast. Remove blue cap under hood, passenger side, near A/C compressor. Cap should have the letter "L" on it. Attach quick disconnect, and read your pressure. It'll probably be zero. Depending on outside ambient temperature, you should have around 45 psi (the instruction book should list what pressure at which temperature). Attach can, hold upside down, repeat when can is empty, and stop when pressure is 45 psi. Don't worry, the pressure will spike to 100 psi when you first start emptying the can. Once it is empty, the pressure will go back down.
The whole kit with 3 small cans is about $35-40. The big can is about $11 separately. Small cans are about $5 separately.
