HRE 542R Wheels
NK BREKR
Mission Hills, CA
Hey Folks,
I'm thinking about pulling the trigger on some HRE 542R tires for my Red SRT 10 in 19 and 20's.
I would appreciate it if you guys can provide me with some Pros and Cons.
Thanks! :2tu:
Nader
New York
That is about the only complaint. I have 545Rs and absolutely love them. The ride is much improved since you do away with the runflats. The rear tire/rim combo alone will save roughly 8-10lbs each. I picked each up(stock and HRE) to compare. Traction is much improved also.
After roughly 2 months on the car the only thing I will say is to becareful of potholes or rough roads. Here in NY there are some bad ones this time of year due to the freezing and thawing from the change in temperatures. With the lower profile and softer sidewall, you can potential bend a rim.
Also I still have yet to have the car recognize the tire pressure sensors. Chuck had some initial problems but I wasnt that concerned. At some point I have to call HRE to see if they have any ideas. I am sure we are just missing something since I purchased them used and the orginal owner's car recognized them fine. I plan to figure it out in the spring.
In the end, yes they are expensive but well worth it. I can not stop staring at the car...
Here is my set 545Rs fully polished which I am sure everyone has seen before...
This is when I had them installed:
This is all cleaned up:
SRTRICKY
Canada
I can't imaigne any cons...
Pros...(the picture can do the talking)
DEVILDOG
VCA Member North TX
VENOMVILLE, TEXAS, USA
VERY NICE! :2tu: Your car looks awfully low. Do you encounter any ground clearance problems or tire rubbing in the fender wells with that setup?
SRTRICKY
Canada
DevilDog its a photoshop. I haven't gotten the motons YET but will be getting them soon so I decided to get a preview over the computer :D
Hirohawa
Venice, CA - USA
HREs are the best looking wheels. i Can't speak for the R series but the regular 540 series has very soft outer edges that will bend in a pothole. I damaged three wheels in one day last winter on my corvette.
SimpleJack
