I can't get the center heat control off!!!!
SRTRICKY
Canada
I can\'t get the center heat control off!!!!
ahh I'm so mad I couldn't get the center heat control cable off!!! Whats the trick to this thing? I can't fold it down some more becuase it seem slike its as streched as far as it can go! I even heard a cracking noise and realize that the area between my headunit and my heat control is now squeeking when prssed down on (not very noticible but still I know its there) Tottally pissed me off I put it back together but I dont' want the next person that will do my install to mess it up now! So are there any tricks to getting this stupid thing off?
SRTRICKY
Canada
Re: I can\'t get the center heat control off!!!!
and on the icruze theres 2 wires coming off of it that need a constant 12 volt source where should I hook these up
Cape Coral, FL
I have the feeling that you are simply trying to take off that one panel- which you cant do. you have to take off the other center panels before it will come apart. The majority of these instructions apply:
RB-1 INSTALLATION INSTRUCTIONS:
1. Remove Shift Knob (two adjustable wrenches)
2. Remove Shifter Bezel (6 Allen screws)
3. remove the lower section of the center console (black plastic around shifter)
Tips:
-it is held on by 4 snaps in the corners, start with the back two, then do the front
-place a piece of masking tape on the frontal panel that covers the gauges and radio to prevent scratches if the lower section rubs it as you pry it up
-E-Brake must be pulled very high in order to slide this panel over it. The e-brake can be pulled to its highest after a short drive -but only ONCE- as it will ratchet itself back down if released and pulled again.
4. Disconnect the two electrical connectors for the windows switches, and the one connector for the power outlet (open outlet to remove connector)
5. Slide the center panel over the e-brake handle and set aside.
6. Remove the Allen screws and 1 Phillips head screw that hold on the frontal panel.
7. "Wiggle" the panel back and forth in order to pop the foam for the upper vents out of the tube it sits in.
8. remove the 3 electrical connectors on the back of the front panel (Start, and 2 heater controls) TAKE YOUR TIME, these connectors are a pain in the ass sometimes.
9. remove the front panel
10. "Pop" the outer dash off slightly. This is the remaining section of the dash which ends on the right side of the console, and continues all the way over to the speedo, tach, etc. There are 3 snaps you want to pop out, 1 on the center right (on the right of the radio) and 2 up on the top. You have to do this to get to one screw on the radio, but you do not want to take this panel off.
11. Remove the 4 Phillips screws that hold the radio.
12. Remove radio and remove the connectors attached to it.
13. Apply the Navigational antenna to the TOP of the metal radio surround, under the vents. With a flashlight, you will be able to see a flat space above the radio where it can be mounted. Position the antenna so the wire points towards the front of the car, and hangs back behind the radio. Easiest way to apply is to reach up behind where the radio was and stick it on.
14. coil up the wire for the nav antenna so it is the same length as the other radio connector. To keep it out of the way when sliding the radio in, stick the original connector though the middle of the coil.
15. Insert the nav antenna connector, the original connector, and the AM/FM radio connector, and reinstall in the reverse order.
NOTES:
-Don't be surprised if the nav reads an incorrect position and direction when you first get the setup installed.
-Nav antenna can see through glass, plastic, etc. WILL NOT see through metal.
-Sirius setup uses an additional control unit and antenna.
Hope that helped!
Cape Coral, FL
As far as the wires;
Leave the blue/white wire connected, it will function properly with it together and no other changes.
The yellow wires need constant power. Technically, it can get power from the connector which you will be plugging into the back of the radio, though you dont have any spare pins to do it with. The empty slot on the connector near the orange wire is actually 12V constant... though some ***** at Monster cable never figured this out. The Yellow wires from the main unit and adapter can be spliced together and either connected there if you can get your hands on a pin, spliced into the constant power supply for the radio itself (difficult), or spliced into the power for the cigarette lighter from the CENTER CONSOLE, not the center bezel. Pay attention to which one gets power ALWAYS, and which is only ACC. you want constant.
SRTRICKY
Canada
Thanks dan I was actaully trying to take it off without removing the actaul middle console tottally! I thought I could manage around taking that off and though I should just move it back!! I guess I will give it another shot before I get someone else to do it! And hopefully I don't hear any cracks this time!!! Just annoying to know its there although otherwise I would have tottaly not known.
Also sorry about my ignorance but when your splicing your basically just taking some of the plastic off one of the wires and wrapping the other one around it then covering with electrical tape correct?
Cape Coral, FL
I highly advise against the "wrap" method. Soldering them is by far the best method, followed by a "T-Tap" connector, such as what is available at Radio Shack.
SRTRICKY
Canada
Sounds good I'll do that then! One last thing how do you get the damn knob off! I was tryign to turn it but it seemed like everything was turning with it! at the bottom of the shifter there is one thing that look like a bolt and the top shifter part itself has like grooves as well. I was guessing you put on on each or am i supposed to put one of the wrenches much lower? thanks
Cape Coral, FL
two wrenches- one on the knob shaft, one on the nut
SRTRICKY
Canada
Thanks dan! Hopefully this time I'm not hearing any cracking noises!! Oh one last question is there any space for the icruze and the module to be put behind the dash?? or am I going to have to bring it out somehow?
Cape Coral, FL
There should be room to mount it under the radio once you remove it. Also, if you need to size down the main unit, pull the back two silver screws out, and slide the black plastic inner out. The silver part is just a flashy "looks" item, not really needed.
SRTRICKY
Canada
awesome thanks for your help dan!
SRTRICKY
Canada
Hey dan before i start opening up the car again tomorrow what color is the 12 volt constant going to the center console? or is it easier to just get the yellow wire into the empty space in the connector? how hard is it to put it into that empty spot? would radio shack have what I need to do it?
Cape Coral, FL
The wire is either Dark Blue/Red or solid red... but I cant tell from the diagram which is which. Just use a voltmeter to see which of the two get power while the key is out of the ignition.
Using the slot in the connector cannot be accomplished without a pin. Radio Shack will not have them. I have a few of them, but the quickest method to get one would be to pick up a CD changer cable from your local dealer (about 20-30 bucks) and stealing a pin out of it. A waste of money, but the quickest.
SRTRICKY
Canada
Dan,
Do you think you can mail me one of those pins! I'm waiting for my speakers to come in anyways I might as well do everything together then. Pm me if you would like! thanks
Ricky
BarryLB
