-FROG-
IF THE PICTURES DON'T COME UP. RIGHT CLICK ON THE RED X AND CLICK "SHOW PICTURE".
This was documented for an RT/10, but can also be applied to later model Vipers as well as other performance cars in general. The steps and locations may not be the same, but with a little research it can be figured out. On a stock car, there is a breather system that allows the valve covers (crankcase) to breathe and not create a vacuum, due to the temperature changes from the running motor. The theory stands, that contaminated air from the valve covers enters into the motor's air intake system through the original breather tube. The breather tube attaches from the air filter housing, to the valve cover. This may effect the performance at a minimum, but we all want pure air entering the motor, for the best combustion possible. So, an easy fix, is to eliminate the original crankcase breather hose. After eliminating the hose, you need to cap off the hole located at the intake filters. Then you will need to place a breather filter in the valve cover hole. Usually, one breather filter is enough, since the two valve covers are joined together by a hose to allow both valve covers to maintain a vacuum free environment. The pictures and steps below should help explain.
Here is the "Mr. Gasket" filter I bought form a local auto parts store. Auto Zone, Pep Boys, O'Reighley, etc... about $6.00. To the left of the filter are some grommets I had 2 regular grommets and 1 fully closed grommet plug. I only used 1 of the regular grommets
Here is my motor setup. A basic 94' RT/10 motor, with cone filters instead of the stock air box. Notice the hose, running from the air filter to the valve cover.
Pop out the grommets that secure the hose.
The holes are exposed here.
Here is the back side of the breather filter. Notice the grommet. It came with a grommet in the package and luckilt it fit in the valve cover hole with a little hard work. I set the other 2 grommets aside, since they were not used.
The air intake filter hole has been pluged up. I may try another plug later, since this one was a little larger than I want. But it works... I purchased this type of grommit plug from a local "Race Shop". I think they come with the "Morosso" brand breather filters for race cars.
Here, you see the finished setup. The air filter has been reattached and the breather filter is now in place. The grommet was pretty hard to wedge into the hole on the valve cover. I used a flat head screwdriver to push it in, when I couldn't use my fingers. Careful not to cut, or push the screwdriver through the rubber grommet. Take your time.
The finished set up, once more.
