varanus
About a week ago I posted "I'm melting" in my viper. Tonight I drove it again and took some temperature readings.
Parked with engine idling over a 10 minute span of taking readings
Ambient outside air temp 62 degrees, temp gauge reads just past 190 to 1st mark, but fan cylces on to keep closer to the 190 while it idles.
Air thru vents with fan on "3" setting: 88 degrees
Air temp in footwells : 90 degrees
Air next to passenger seat between sill and seat: 95 degrees
All I can think of is that the headers may be throwing out a lot of heat even though they are coated in addition to my hot cats.
So my ideas are are to use thermotec products:
http://www.thermotec.com/products/full/full.html
1. Wrap all exhaust pipes from the end of the header collectors with header wrap.
2. spray the inside of the side sills with 2000 degree hi temp coating
3. Enclose or wrap cats with muffler cat heat shield
4. line side sills with aluminzed heat shield material
5. Put on header blanket
6. Maybe use some of the heat shielding under my mats or under the carpet.
I know it sounds extreme, but the car really is unpleasant to be in. It was too hot tonight at 62 degrees. I drove down the freeway with both windows down , but my feet we still uncomfortable from the heat. Whenit get 80 degrees I think I am actually losing weight from sweating it off.
So have any of you done this or something like it before?
will wrapping any of the parts mentioned damage the parts?
Any help is appreciated.
