is the NACA duct susposto **** air when you hit the gas?
STUGOTS
NY/CT
is it also susposto make a sucking sound when tou hit the gas?
if you put your hand in the duct is there susposto be hot air there?
Sam 01 RT10
Las Vegas NV
Depends on if you have a Vipair.
If your car has smooth tubes you will hear a whining or possibly sucking sound. I've never felt hot air coming out of mine.
STUGOTS
NY/CT
no i don't have a vipair.
no smooth tubes but i do hear a whine.
and not hot air comming out but i feel it if i stick my hand in there pretty deep
STUGOTS
NY/CT
lol i hear what your sayin.
but is it susposto **** when you hit the gas?
joe117
Maryland, USA
Stu,
You could do a little research here.
You probably have seen pictures of wind tunnel testing where there are little tufts of yarn all over the test object.
You could stick a bunch of these on the front of your Viper, temporarily, and have someone drive ahead off your right front and video the tufts to see what's going on.
Then you could show us the video. You could be the man with the answers.
My bet is that the NACA duct on the front of the Viper was put there by the same team that designed the body. I seriously doubt that any thought went into function.
It's only there to look nice. It may not ever "****".
Viperfreak2
Duncan, SC USA
The filters muffle the sucking sound. Yes, hot air will come out of the vent at idle, hell it comes out every gap on a Viper. K&N's make more noise than stock and no filters make a cool hissing noise, like Ferraris do.
Oh, and don't EVER stick you hand in too deep. It may cause brain damage.
ViperJoe
Virginia
"and not hot air comming out but i feel it if i stick my hand in there pretty deep"
ROTFLOL... This is a joke right?
Well duh.....your hand is up IN the front of the engine compartment.
YES, the feeling of heat is ok, it means you have driven your car.
STUGOTS
NY/CT
ok guys thanks for then answers.
Viperfreak its not susposto **** air at idle?
Viperfreak2
Duncan, SC USA
Yes, it is. BUT the heat under that hood is too much for the small amount of air going in the engine at idle. Try holding your hand over a throttle body at idle. Then have someone rev the engine and try it again.....ouch.
STUGOTS
NY/CT
i got ya ok cool thanks alot ViperFreak this put my fears to rest
thanks again
YouWish
U.S.A.
Does anybody here listen to the Bob and Tom show? The skit Mr.Odvious comes to mind...
STUGOTS
NY/CT
i just asked because u put my hand there while a friend hit the gas and felt nothing
joe117
Maryland, USA
The NACA duct was developed to be used as an efficient, low drag, air intake for flat surfaces where the air is moving across the surface. The side of an aircraft would be a typical use.
The NACA duct on the front of the Viper may or may not work properly. I believe it's just for show. There are probably better ways to get air into the intake.
yellow94
connecticut
("Re: is the NACA duct susposto **** air when you hit the gas?")
Holy s**t. I have a Gen 1 and don't have the NACA duct. When I hit the gas, nothing *****......am I in trouble??
yellow94
connecticut
UT OH!! I need help!! It's 2:00 am est and I'm in my driveway revving the heck out of my 94. I don't have an NACA duct and don't feel any sucking action. Am I in trouble? Do I need an Arrow rebuild? How do I get the NACA action???
scottgf
Southern California. USA
Chris,
I guess Gen 2's ****, Gen 1's dont **** :)
Cheers,
STUGOTS
NY/CT
gen 1 the air comes from the facia gen 2 it comes from the naca duct, and the vipair kinda combines both if you will, it takes the air from the fasia and redirects it into the air box so it basicly makes gen 1 and gen 2 airflow so you know what i bet it does increase hp (at higher speeds anyway) and reduces drag as well
tbone96
