K & N Whistle
zen garage
Glenview Illinois
Question for you guys with K & N intakes. How loud are yours. Mine squeels like a stuck pig at idle, especially after start up. It sounds like is is grasping for every bit of air it can find.
ViperGMC
TN
The noise you are hearing is the air rushing through the idle air control motor, which is the 3/4" hose on the passenger side connecting the throttle body to the K&N plastic. If you smooth out the inlet on the K&N, you can alter the noise to your liking. It is only used at idle.
Z
zen garage
Glenview Illinois
Frikkin excellent. Now how do I smooth out the inlet?
ViperGMC, your car sounds like it is built tough. I aspire to have a signiture like that.
ViperGMC
TN
file, drill, box cutter, basically clear out any flashing mold parting lines sharp edges etc. results will vary
I like the blah, blah on yours, LOL, I think I might start using that.
viperrt
Poway, CA, USA
Sounds like the problem owners had with the original K & N systems. Mine sounded like it had a supercharger when first installed. Drilled out both orifices in the composite tube and cured the problem.
Do a search as someone actually posted the drill sizes used to open the orifices.
Vipermann
Texas
The whistle went away when I 'drilled-out' the K&N fittings ... per earlier threads on the topic
Racer Robbie
Guilford, CT-USA
all you need to do is drill out the small hole 3/8" and the large hole 1/2". then use 1/2" self stick foam tape under the K & N tube and on top of it between the 2 air box houshings. I AM LOOKING TO BUY A K & N USED SETUP. ALL I NEED IS THE V TUBE, HOSE, AND GROMMET. EMAIL ME AT [email protected]
miwr
